Jr 8103
Old 02-23-2003, 02:05 PM
Hawk21
My Feedback: (7)
Default Jr 8103
My jr 8103 turn off when it gets a bump like when I close
the antenna or simply a bump. Does any one have this problem?
I think it is nothing big and that is way I do not want to send it
to check. Thanks for your help.
Old 02-23-2003, 02:36 PM
MachinShin
Default Jr 8103
Nothing big unless it gets bumped while flying! Sounds like a loose electrical connection (or a possible bare contact shorting out when bumped). You might want to try removing the back of the transmitter and at least look for anything obvious.
Old 02-23-2003, 02:39 PM
Hawk21
My Feedback: (7)
Default Jr 8103
I recently did that and did not find anything loose.
Old 02-23-2003, 05:58 PM
marine
Default Jr 8103
Check the fuse holder in the Tx
Old 02-24-2003, 04:24 AM
visioneer_one
My Feedback: (506)
Default Jr 8103
That's your solution right there. The 8103 fuse holder clips are a little on the weak side, and loosen over time. Pull the fuse, squeeze the contacts a little, then reinstall the fuse.
Old 02-24-2003, 11:33 AM
Hawk21
My Feedback: (7)
Default Jr 8103
You guys nailed the problem.
The fuse holder was loose.
Thanks for the help!!!.
Benny
