Trouble with JR 811 servos
WI
I have had two 811 servos fail when running them on 6 volts, both failed on the ground, neither ever flown, they were just idling on the bench when I was working on the rest of the elevator linkage (the failed servos were on the throttle). They were not binding and there was no over travel problems, they just died while not doing anything..... Wonder if anyone else has had problems with 811's on 6 volts?
WRK
WRK
RE: Trouble with JR 811 servos
I used two of them in my seagull edge running on 6V with no problems. I must admit I did not fly this setup a great deal but for the short time I used it they worked fine.
