dx6 and G3.5
dx6 and G3.5
has anyone been able to use the DX6 radio with G3.5. if so please tell me how. i was thinking this would be a great way to learn to setup the dx6 with out crashing my real heli's. i already have fsone with dx6. but fsone just is not g3
RE: dx6 and G3.5
I just got it to work the other day. You need to have it set up with the CCPM mode OFF! You will also need to run the trainer cable through the included G3.5 transmitter and select the 6 Channel Transmitter mode under the joystick selection. You need to play with the channel mapping to get everything going smooth but it helps to learn the settings on the TX without crashing your heli, which helped me out a lot since this was my first TX of this kind!
