Futaba 9C Help
My Feedback: (10)
GA
Futaba 9C Help
Guys, could you please refer to the link listed below? No one replied in the Futaba forum yet, and I could use the help.
Secondly, could someone please tell me why the Futaba 9C transmitter I have says 9CAP, BUT the box that it came in says 9CAF?
The receiver says R148DF, which is the one that goes with the 9CAF.
BUT my transmitter says 9CAP.
Can someone please explain?
Here is the link to my other questions. Thanks so much for any help.
http://www.rcuniverse.com/showthread...01&forumid=150]
Futaba 9C Help
The 9CAP and CAF are the same transmitter, but different packaging. Both are capable of PPM or PCM operation, which is probably why they both say 9CAP. Not to worry; they all come like that.
My Feedback: (16)
Futaba 9C Help
Ditto to what Ryan said. Plus... when sold as the 9CAP, it comes with a PCM RX and when sold as 9CAF, it comes with a PPM RX.
If you want to run the other, it's a simple menu item and turn the radio off and on.
Mike
Mike
My Feedback: (16)
Futaba 9C Help
As far as answering your other question, Yes, you can run a "Y" harness or you can use two channels. I think on mine, it's 2 and 6.
Sorry, not sure about the other part of your question. I think I understand what you're saying, but don't understand why it would go from 17% and then drop all the way. Could it be an EXPO problem? Like if you had a lot of expo, the first part of the movement would be soft and then it would finish out the rest very quickly.
Mike
Mike
My Feedback: (10)
GA
Futaba 9C Help
Guys,
Here is my main problem that I could use help with.
I am using a Y harness with my two ailerons. Plugging into channel 1, of course.
However, I cannot figure out how to get both ailerons to trim out. WHen I get ONE side at the neutral position, the OTHER side is out of neutral. I know there is a way to adjust one servo at a time, but cannot figure it out. Could some one give me a step by step way to adjust ONE aileron at a time?
Futaba 9C Help
If you're using a Y harness you cannot adjust each servo independently with the transmitter. Your only choice in that scenario is to trim one neutral then mechanically (adjust the clevis) neutral the other one. Is there some reason for not using two channels for ailerons? If you did then you could adjust each servo individually.
Joe
Joe
