Help with a T9CAP & ailerons
Hi
Plugged my ailerons into channel one and seven. Channel one works, but I can't get Channel 7 to work. In other words, only the right aileron works. I know I'm doing something wrong with the programming, but don't know what.
Handyandy
Handyandy
PA
go to {ail-dif } in the advance set up by holding the mode button twice. Activate the mix, If you get (inh) and cant turn them on you must deactivate any functioning switch on channel 7 for the Ail-dif to work.
*If you recieve error msg(inh) OTHER WING MIXING is on elvon or flaperon need turned of..
