TF & RF crystals Does anybody know the Country of origin for this terminology please????
Hi,
Does anyone know the country that uses the terminology TF & RF instead of TX & RX here in the UK Please?
i have purchased some crystals for FM 40 Mhz use in the UK they had the orriginal manufacturers name on the pack but do not seem to work in my UK radio, I was wondering if the frequency might be slightly off because they are meant for use in another country?
I have had some problems finding the right crystals for my Hitech Zebra radio and always seem to be fobbed off with something inferior to that of the orriginal specification.
however this time i thought I had it right as the packaging said Hitech.
kind regards. Nigel.
RE: TF & RF crystals Does anybody know the Country of origin for this terminology please????
To be safe, try to use crystals from the same vendor as the maker of the transmitters. Different tranmitters use different oscillator design (is it a Colpits, Hartley or ??) and may require a different cut on the crystal. Also, is it using a 3rd or 5th overtone crystal? Just going by the frequency marked on the crystal doesn't tell you all the necessary information.
ORIGINAL: nigel1 Hi, Does anyone know the country that uses the terminology TF & RF instead of TX & RX here in the UK Please? i have purchased some crystals for FM 40 Mhz use in the UK they had the original manufacturers name on the pack but do not seem to work in my UK radio, I was wondering if the frequency might be slightly off because they are meant for use in another country? I have had some problems finding the right crystals for my Hitech Zebra radio and always seem to be fobbed off with something inferior to that of the orriginal specification. however this time i thought I had it right as the packaging said Hitec. kind regards. Nigel.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
That doesnt really help much I'm afraid the terminology you use dosent tally with the information I have on my crystals.
I have no idea what language/country would use capital 'F' where we use a small 'x'.
My advice/opinion is that if they can't get the abbreviation 'right' then I don't have much faith in the product-------particularly a crystal.
ORIGINAL: onewasp I have no idea what language/country would use capital 'F' where we use a small 'x'. My advice/opinion is that if they can't get the abbreviation 'right' then I don't have much faith in the product-------particularly a crystal.
FWIW the crystal tab abbreviations "TF" in lieu of "TX FM", "TA" in lieu of "TX AM", "RF" in lieu of "RX FM, "RA" in lieu of "RX AM" is clearer and has been is use for many years by brands other than Futaba. A manufacturer, who cuts and supply xtals to USA military, has confirmed that Hitec xtals are manufactured to higher specifications than Futaba and JR xtals.
Regards
Alan T.
So I have purchased a Tx crystal and an RX crystal in the same package marked Hitech crystals but the crystals have on them TF for FM transmitter and RA for AM reciever, if this is so accoerding to your infomation why would the crystals work when there are no other radios being used in the vicinity, if they are both of different frequencies surely they wouldn't work at all...Strange.
regards nigel1
regards nigel1
regards nigel1
regards nigel1
nigal1. Typically a receiver crystal is 455 KC different than the transmitter frequency for single conversion receivers and 11.7 (approx) MHZ different than the transmitter crystal frequency for dual conversion receivers. Transmitter crystals are usually 1/3 or 1/5 of the frequency being transmitted (the transmitter usually multiplies the frequency of the crystal be either 3 or 5). That is why you can not use a receiver crystal as a transmitter crystal. Whether the receiver cystal is above or below the transmitted frequency is what determines whether the reciever is using positive or negative shift.
Rodney,
Thanks for that but youve completely lost me in the great jungle of electrical knowledge.
regards. nigel1
regards. nigel1
