sullivan smoke pump and digital servos.....
Reply
Old 06-22-2007, 01:15 PM
jmehl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default sullivan smoke pump and digital servos.....
Have a Sullivan Smoke Pump and Digitial Servos....when I plug the battery into the smoke pump which is plugged into the Rx all the servos shake uncontrollably....any ideas why???? the battery is in great shape.
jmehl is offline
Old 06-22-2007, 01:39 PM
pilotpete2
pilotpete2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: sullivan smoke pump and digital servos.....
It almost sounds as if the smoke pump battery voltage is backfeeding to the receiver, what voltage battery are you using for the pump?
Pete
pilotpete2 is offline
Old 06-22-2007, 04:43 PM
gadix
gadix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
try to isolate the problem:
1.change battery
2. change channel in RX to see if you get the same interference?
3. the skyriter is OFF not running,correct? if yes, than it is RF nois from the pumo motor - suliven will replace for free on this case if is!
4.what kind of batt? NICD, LIPO,NIMH? lipo is best - lighter and no need for regulator just a 7.2/2cell/1100mah will do the work
5.check all connectors
good luck
gadix is offline
Old 06-22-2007, 10:34 PM
jmehl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
4.8v
jmehl is offline
