JR8103 no middle flap setting
Reply
Old 06-22-2007, 06:01 PM
Rejean Boucher
Rejean Boucher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default JR8103 no middle flap setting
In airplane mode, is the Flap/mixing switch on a JR8103 only limited to two flap settings, that is: fully up or fully extended? Since this switch can be toggled in three steps in heli mode, is there a means of programming the flaps to move to retracted, half or fully extended positions? Curently I have the flaps plugged to Aux 1 and the other flap servo into Aux 3. When I toggled the switch down to land mode the flaps move as advertised but I would like the option of a half setting also. Is it possible within the airplane mode?
Reg
Rejean Boucher is offline
Old 06-23-2007, 10:54 PM
Rejean Boucher
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: JR8103 no middle flap setting
I gave up in airplane mode (ACRO) and had success by utilizing glider mode. I should have done this from the very beginning; flaps in glider mode were very easy to set up and I was able to maintain independent control of each flap servo. "Y" harness for ailerons was plugged into ch # 2 and flap servos were hooked to ch# 6 and 7
Old 06-24-2007, 11:03 AM
Eric.Henderson
Eric.Henderson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Rejean Boucher
Reg
Technically it can be done. (It is much easier with a JR radio that has a three position flap servo channel and switch).
If you use a mix option you will see in the switch-selection-line on the screen that you have the option to uses ON, FLAP, ELEX OR MIX. The LAND and ELEV are on the same physical switch.
You get the follwing three positions. You ignore the options to use these functions
ELEV
OFF
LAND
You will have to use two separate mixes.
- Mix Flap-channel with Flap-channel and then,
- You would need to use one mix to set the position for (ELEV)--which would be the flaps-up s/w position.
- You would dial the mix throws The center position (OFF)--would be 1/2-flap, or whatever you dialed, s/w position.
- Then a second mix would use (LAND)--as the full-flap setting s/w position.
If you are using two flap servos you will probably have to use a total of five mixes
Maybe even six mixes if you want auto-down-trim for each flap setting. There is one auto down-trim option avaialbl in the flap option but it would only work on the full-flap setting.
Thsi note is proably not helpfull but you asked if it could be done with an 8103. The good stuff in the 9303 and beyond obviously costs more.
Regards,
Eric.
P.S. Be sure to dissable the flap-pot-trim-knob value.
Eric.Henderson is offline
Old 06-24-2007, 01:14 PM
Rejean Boucher
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Eric for your input, after spending most of my saturday on the radio forums & countless flap mix attempts in airplane mode I did manage to get the flaps to off, half and full setting with the flap mix switch but only in the one servo flap configuration ( Y harness). In the two servo config, I was never succesfull at mixing that [:@]second slave flap servo to the master servo to achieve the desired 3 flap positions. That's why I ventured over to the glider mode screen.
I haven't totaly given up, I am going to field this question to Danny Snyder in the JR Radio forum.
