dual servos on aileron and flaps help setup
Old 03-05-2003, 11:02 PM
robrc
Default dual servos on aileron and flaps help setup
got a jr 8103
trying to setup with ailerons and flaps but i cant get it to work correctly
i tried it on the glider setup wing type which worked great till i tried my throttle and then the flaps moved when throttle is applied anyone know how to correct this or how to set it up on regular acro wing type what channels do i use and how do i set it up getting very frustrated
i want the ailerons to work as ailerons and the flaps to function as flaps why is this so difficult
also should i use a y connector on ailerons or flaps or just straight the the channels
PLEASE HELP
