DX7 No Trainee
DX7 No Trainee
I just bought a new DX-7 and have put it in a Cub to test. I did a little bit of programing and tried to figure out how the Spectrum works, I'm use to a 9C Futaba.
The first problem is The transmitter screen is flashing "No Trainee" how do I get rid of that?
Second I would like to have a 3 position switch ( be normal in up, Idle down in middle and throttle cut at down position.
GA
RE: DX7 No Trainee
can't help you with the trainee deal... but may I suggest that you do not put the low idle and throttle cut on the same switch...
it is too easy to accidently push the switch too far and cut the engine while still flying....
just a suggestion
just a suggestion
RE: DX7 No Trainee
ORIGINAL: exeter_acres
just a suggestion
just a suggestion
Thanks I got rid of the no trainee
My Feedback: (23)
RE: DX7 No Trainee
turn on the TX while holding the left rocker down and the select button. Navigate to the trainer menu and change it to disable. This is from memory but the procedure is pretty close to that.
