Royal EVO V-Tail Mixer
FL
I seek help from the EVO gurus.
I have just set up my V-tail sailplane on the EVO 9. The first problem encountered was the rudder was reversed. The manual says to correct this in the V-tail mixer so I reversed the rudder in the mixer, changed 100% to -100%. The rudder now works correctly when the transmitter is activated but it caused a different problem. If I monitor the servos, the rudder show both servos working together and the elevator shows the servos going opposite directions. When elevator is added to any of the mixers, it activates the rudder instead of the elevator. I've tried reversing the servos and that doesn't help.
How can I get the elevator and rudder working correctly?
Thanks in advance for your help.
Steve
Steve
FL
RE: Royal EVO V-Tail Mixer
OK, I got the transmitter portion straightened out by just reversing one of the tail servos. The rudder direction is still wrong though and reversing the mixer doesn't help. Any suggestions?
Steve
Steve
