just got a bunch of neat RC stuff!
Reply
Old 07-09-2007, 12:03 PM
pywackit
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default just got a bunch of neat RC stuff!
Hey Guys,
This only happens to some one else right, this time it was me! I'm helping a friend clean out her Dad's house since he's passed on but she gave me all of his RC airplanes and equipment! Now this is old stuff that needed dusting off and I still have to sort all the stuff out but I found a brand new JR crystal still in the bag....can I use this in my JR box that I've been useing for a buddy box? It doesn't have a crystal and I'd like to use it for another plane.
Besides this crystal there's a sullivan starter and field box and two OS engines, a 70 4 stoke and a .25 2 stoke. But there is more even better....A new digipulse charger and radio field case that holds two radios. He also had some fancy JR digital radio that needs the internal battery replaced but that should be cheap...I hope! Then there's the 8 foot wing span cub with flaps! Flaps....I can hardly handle ailerons right now...LOL! There were also two Waco biplanes but they were crashed really bad so they're gone but I did take all the good stuff off them.
pywackit is offline
Old 07-09-2007, 01:23 PM
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: just got a bunch of neat RC stuff!
ORIGINAL: pywackit
Yes, you should be able to, if it is a transmitter crystal, and not a receiver crystal. They are different. Also, if it's not the same channel as the transmitter was originally on, you need to have the transmitter retuned to match the crystal exactly. Otherwise you can cause interference on adjacent channels, and it is also illegal, in the US, to change channels on a transmitter unless you are a licensed tech.
TLH101 is offline
Old 07-09-2007, 01:35 PM
pywackit
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info Terry. I'll check to make sure just what crystal it is, transmitter or receiver. I've got another question and this one is just because I don't understand about this electronic stuff.....on the crystal i believe it say's 72 mhz or something like that. I believe that's not the frequency if I'm not wrong?
pywackit is offline
Old 07-09-2007, 02:56 PM
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, that's not the frequency, it's the band. In the US aircraft use 72, 50 & 27 Mhz, surface vehicles use 27 & 75 Mhz
TLH101 is offline
Old 07-09-2007, 03:00 PM
onewasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Unfortunately it is not legal for you to replace a Tx crystal----not in the USA.
You should send the equipment to the respective factory repair facilities for a check out before attempting to use it.
That will protect you as well as others.
onewasp is offline
Old 07-09-2007, 07:43 PM
bruce88123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
IF the crystal says 72.xxx then it IS the actual frequency and you can look up the channel it belongs to. If it is a RX crystal, you still need to determine if it is single of dual conversion type.
bruce88123 is offline
Old 07-10-2007, 08:29 AM
pywackit
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I looked at it again last night and it turned out to be an RX crystal instead. A single or dual conversion? what??? you lost me on that one Bruce...
pywackit is offline
Old 07-10-2007, 08:39 AM
fizzwater2
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is the crystal in a colored plastic holder? Sort of a "cap" that fits over the top of it? What color is it..
fizzwater2 is offline
Old 07-10-2007, 10:26 AM
bruce88123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: pywackit
This determines what type of RX it will work in, a single or dual conversion type. Of course if it doesn't match your TX freq, who cares?
Old 07-11-2007, 08:55 AM
pywackit
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I checked it and it's gray.
pywackit is offline
Old 07-11-2007, 12:02 PM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did you thank your friend? How?
dirtybird is offline
