Sullivan Smoke Pump Not Pumping
Reply
Old 07-13-2007, 01:33 PM
jmehl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sullivan Smoke Pump Not Pumping
Not sure if this is the right forum...
Just bot my sullivan smoke pump and had it up 3 times. Worked great the first 2 times and the thrid time the pump sounds like it running but nothing is happeneing. It make s a low pitched sound but nothing is pumping.
Battery is good, connections all good, smoke oil in the tank...
Any suggestions.
thanks
jmehl is offline
Old 07-13-2007, 05:24 PM
quist
My Feedback: (198)
quist's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Sullivan Smoke Pump Not Pumping
I had the same problem. It worked once, then the speed control went out. So I put on a GWS esc and it worked twice, then it stopped pumping but the motor was running. SO I took the pump end apart to find out the motor shaft was free spinning inside the gear that make the pump work.
It really is a horrible design of a pump. The gear is just a press fit on the motor[:'(], it should be keyed.
I should have sent the unit back, but I took it apart instead. I just had to do it[8D]
You should send it back for a new one.
quist is online now
Old 07-13-2007, 05:25 PM
quist
My Feedback: (198)
quist's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
quist is online now
