RECIEVER COMPATABILITY
Reply
Old 07-19-2007, 06:24 PM
sefty
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RECIEVER COMPATABILITY
WILL A JR XTAL WORK IN A HITEC OR FUTABA RECIEVER
I AM USING A JR TRANNY XP652 ANY HELP PLEASE APPRECIATED
MIKE...
sefty is offline
Old 07-19-2007, 06:33 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RECIEVER COMPATABILITY
First if you use a Hitec Rx it must be a positive shift version or one of the shift selectable, autoshift models. I don,t beleve futaba sells anything in Rx's that is selectable.
John
JohnBuckner is offline
Old 07-19-2007, 06:36 PM
sefty
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
CHEERS JOHN AM THINKING OF A GWS MAYBEE I THINK THEY AR JR SAFE
sefty is offline
Old 07-19-2007, 07:14 PM
pilotpete2
pilotpete2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, as a rule most JR receivers are single conversion and most Futaba and the better Hitecs are dual conversion. A single conversion crystal will never work in a dual conversion receiver. Mixing brands of crystals and receivers is never a good idea.
The negative and positive shift issue that John referred to is only on the 72Mhz band that we use in North America, in the UK you do not have to consider that[8D] all brands of PPM/FM receivers will work with any brand of transmitter for you. But using the improper crystal for your receiver is the most common cause of folks asking "why won't my radio give a good range check and it glitches like crazy"
Good luck,
Pete
pilotpete2 is online now
Old 07-19-2007, 07:29 PM
Mac_Man_UK
Mac_Man_UK's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The golden rule is ALWAYS to use the Manufacturers crystal. Never NEVER use a 3rd party's crystal.... it may work or appear to work but invariably it will give you crap range.
Mac_Man_UK is offline
Old 07-20-2007, 06:28 AM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: sefty WILL A JR XTAL WORK IN A HITEC OR FUTABA RECIEVER
I AM USING A JR TRANNY XP652 ANY HELP PLEASE APPRECIATED MIKE...
Crystals are no longer interchangeable between brands.
Transmitter Crystals - do not interchange between brands except as listed by GWS
Crystal Compatability Chart for RC units (courtesy GWS)
The following may also assist:
Single Conversion vs Dual Conversion - fact sheet
IPD (Intelligent Pulse Decoding) Receivers - FAQ .pdf file
and RC Groups "Sticky"
What type of crystal do you need ?
see also sub section "Crystals, Oscillators & Piezo " under "Radio Systems, Accessories, Alterations and FAQ" on my web page.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline
