futaba 149DP with 6v
Old 07-30-2007, 05:23 AM
Ragz
Ragz's Avatar
Default futaba 149DP with 6v
i have been using a futaba 149DP with 6v supply forever...suddenly one reciever has gone crazy. It jitters with a 6v supply. In case of a 4.8v it behaves. What could have happened out of the blue?
Old 07-30-2007, 07:35 AM
exeter_acres
exeter_acres's Avatar
Default RE: futaba 149DP with 6v
how does a Rx jitter?
Old 07-30-2007, 07:50 AM
Ragz
Ragz's Avatar
well...ofcourse the rx doesnt [&:] ..but the servos that are connected to it do....move at will..and when moved with sticks..start jittering.
Old 07-30-2007, 07:55 AM
exeter_acres
just playing!
sometimes it is normal for the servos to jitter a bit with a very fresh....just off the charger battery.....
does it go away after a few minutes or does it stay....?
which servos?
Old 07-30-2007, 08:48 AM
Ragz
Ragz's Avatar
doesnt go...it stays. Srvos are JR 3421 digitals and some more...besides servos jittering, the ones that dont jitter move jerkily.
Old 07-30-2007, 10:25 AM
Campgems
Any strange behavior on a receiver should be resolved. I would pack it up and send it to Futaba for a checkout. If you have had a hard landing or two on it, or there is a lot of viberation, it may have lost one of it's ceramic filters. The 149DP is worth the cost of having it repaired by Futaba.
Don
Old 07-30-2007, 10:28 AM
Ragz
Ragz's Avatar
hmm..it was in my 33% extra 300 powered with a da100. I guess the vibrations got to it then? Will send it across.........
Old 07-30-2007, 01:41 PM
BarracudaHockey
BarracudaHockey's Avatar
Yep, get it looked at, cheaper then replacing a plane.
Old 07-30-2007, 09:18 PM
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
You may want to checkif the servos can handle the 6V... I understand some JR have issues...
