Can the Quality of battery affect the range in TX?
Reply
Old 07-31-2007, 05:01 PM
Hiaboo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Can the Quality of battery affect the range in TX?
Just like the title said. I'm just curious much alike the quality of the battery affects runtimes and such.
Hiaboo is offline
Old 07-31-2007, 06:40 PM
JPMacG
Default RE: Can the Quality of battery affect the range in TX?
Runtime, yes. Range, no.
JPMacG is offline
Old 08-01-2007, 05:18 AM
Piet Le Roux
Piet Le Roux's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not much. The transmitter voltage will have a significant affect on power output. This differs between different designs by let say the transmitter deliverers 1 watt at 10.8 volt, at 9.6 volt the output will be about 0.6 watt. This sounds a lot (40%) but you would only notice reduced range if your output dropped by 50% ( -3dB). One must remember that changing your transmitter power by 50% does not change your range by 50%.When you collapse the antenna of your transmitter your are reducing you radiated power by about 25 times(-14dB) , and you should still get a range of 60-65 feet.
Piet Le Roux is offline
Old 08-01-2007, 05:52 AM
Hiaboo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Interesting - because this is the situation I have.. (although i don't think it's a radio issue but it's acting like one) With my truck i have a MM5700 in it, if I go 75 feet with it, it'd stop and glitch. Previously with a brushed setup, I could go 600 feet or whatever (I havent measured it) with no issues. It looks like the MM system is causing severe interference. I tried this with a different radio system but it still happens, I'll have to try to get a entirely different RX like a futaba for example and try that.
Hiaboo is offline
