Futaba 6EX 2.4 Ghz lost ID Code
Hi Chaps
I left my 6EX Tx on and accidentally discharged it completely, Trickle charged it for two days and went flying.
No response from either of the two models I took, just flashing green on R606FS
Ok, I succesfully relinked both rx and flew
Now I got home and try my other model and I had to relink that as well !
So I must have lost my original Tx ID
so much for the "individually assigned unigue ID code"
What ID do I have now ????
Martin
Martin
RE: Futaba 6EX 2.4 Ghz lost ID Code
martinh
You should ask Danny on the spektrum product support forum: [link=http://www.rcuniverse.com/forum/forumid_116/p_1/tmode_1/smode_1/tt.htm]http://www.rcuniverse.com/forum/forumid_116/p_1/tmode_1/smode_1/tt.htm[/link]
My Feedback: (18)
ORIGINAL: Feric Jagger
Once you re-bound the receivers have they stayed bound? Since Futaba doesn't have the model match feature it is not as easy to tell if the receiver and transmitter exchange IDs (GUIDs) or if the receiver simply records the transmitters GUID...
ORIGINAL: GalenB
Since this is a Futaba transmitter I doubt Danny will be of much help... You could post in the Futaba Support forum and see what Bax and Krysta have to say...
Martin
ORIGINAL: GalenB
Being new to the hobby I do not yet have a computer transmitter. I have been looking at the Spektrum transmitters (Danny says they are great, he's so helpful). It is my impression that the Futaba transmitters are better but more expensive. However, I have no basis for making a judgement. Is there anything wrong with the Spektrum transmitters? What would you recommend to someone who is not afraid to spend a stupidly large amount of money upgrading a $150 helicopter?
Stephen
ORIGINAL: martinh
Hi Chaps
Martin
Hi Chaps
Martin
I picked up a new FS607 for a model originally on my 6EX Tx so I thought I would use this rx with the 6EX to save time setting up again on FF9/TM7 guess what I did not have to bind the new rx to the 6EX so my 6EX must be on the default GUID probably the factory test ID
I have tried 50 or so times to get through to Futaba Support in the UK now (Rpmax Enfield)
As far as I am concerned now the whole lot will probabley be referred to trading standards in the UK and the as though I have no flight problems the 6EX is definitely not on it's unique GUI and it also might be a matter for OFCOMM the RF regulator
Martin
Martin
