Y Harness wont work with five cell pack
My Feedback: (10)
NH
Is it normal for a "Y" harness with a choke/amp, to act up with a five cell pack?
Throttle, rudder, ailerons, were all OK. Just the elevators on the "Y" with a choke were extremely erratic.
As soon as a regular four cell pack was substituted, elevator servos went back to normal.
WI
5 cell pack
Hi
I was also having problems With flap servos with a Hitec flash 5 radio with Super Slim receiver. Was using a Y on channel 5 of the receiver output. I tried different Y's, servos and was going to give up and then tried a Futaba receiver and no more problems. Don't know why, but it works.
Harvard
Harvard
My Feedback: (10)
NH
Thanks everyone for the input.
In the application at hand, there is a diverse mix of "brands" involved for each task required.
My particular experience over the years has been met with very good success regardless of manufacturer( J, F, or H.), provided the obvious "common sense" is applied when necessary.
This instance is the first time that a five cell pack has caused some concern, simply because of the choice of "Y" harness.
At this time, the choke has been removed and as anticipated, all is back to normal, so it seems that JWN is correct about that particular device being sensitive to 6v packs.
A small lesson learned, lets hope it helps someone else also.
