Gyro Switch unit
BC, CANADA
RE: Gyro Switch unit
I can't find it on horizonhobby.com or on google.
ORIGINAL: beepee
I have one that came with my Expert EX-100 Gyro. It was and should still be available separately. Go to Horizonhobby.com.
Bedford
Bedford
My Feedback: (55)
ORIGINAL: bobferguson
I am looking for a unit that allows me to shut off a gyro. I found one to use with a GWS pg03 but I can't find one now.
The Futaba GY 401 gyro allows you to remotely (from your transmitter) to turn the gyro off. This is done through the remote gain feature which turns the gyro off when the gain is set to "50". When you remotely switch the gain to >50 it goes into the heading hold mode and when it is set to <50 it is set to the rate mode. The key element is that the gyro is controlled by a separate gain channel on your receiver. My only experience is with the JR 9303 which has a gyro gain function that makes it very easy to program. Ikarus and Eflite (I think) also make a remotely controlled gyro. Here is a good thread that describes the whole process http://www.rcuniverse.com/forum/m_60..._1/key_/tm.htm
Howard
BC, CANADA
Thank for the link. I have found the GWS pg-02 which looks like exactly what I want. I am all ready using a PG-03 in my Newbee, with no remote gain. the PG-02 has remote gain. Also GWS make a PC-03 (I thinnk) that is a switch that would work with the PG-03. They are only about $50 while the 401 is more like $140. I found one source for the PG-02 but they will not ship to Canada. So my local hobby store, well 1hour drive local is checking into for me. He carries the PG-03. Hopefully he can get it that or I can order from China.
I just remembered and checked the planes I want to use have only four channels or channel with the fifth channel use as channel six for flaprons. O and the costs keep going up.
