Fp electro'Dynamics
BC, CANADA
Fp electro'Dynamics
can anyone tell me if they have used a EDR-111 POW'R BUS PRO
optically-coupled amplified servo isolator.
i have one on order but im still not sure ????
Re: Fp electro'Dynamics
My Feedback: (7)
That is the reason I developed the Fiber Optic servo extensions which fix more then one problem, it isolate the servos from the receiver, eleminates the long signal wire syndrom, and boost the signal so that you could attach up to 7 servos to the one extension. Should you have a bad servo, it cannot feed back noise to the receiver. Also you now have the possibility to have a complete redundency system.
