Spektrum DX7 Lockout
Hi guys my spektrum dx7 radio keeps locking out on me when i am in flight, i am using a AR6200 full range receiver, when i do the range test it is fine, when i start flying around and take it up it just locks out and goes in to fail safe till its back in range , i am using a pheonix 60amp speed controller, i have tryed re-binding it, i have another plane with another spektrum receiver in it but i am to scared to fly that in case it locks out 2. (Has the AR7000 got more range)
Any suggestions?
Many thanks
Any suggestions?
Many thanks
RE: Spektrum DX7 Lockout
Hi Mate,
I am using the flight power 11.1v 3700MAH with a castle creations phoenix 60 AMP speed controller.
J
J
AR
It could be a low voltage issue from the bec. You need to use a flight pack battery for the receiver or a UBEC (ultimate BEC). It's probably rebooting from low voltage, a common problem with a speed control BEC.
I had the same problem with the battery that come with the DX7, purchased a 5 cell battery and I have never looked back. bloody great radio.
Smo0
Smo0
ok guys would this help my lockout http://www.alshobbies.com/shop/looku...7576&Desc=volt The DX7 is a great radio but i have lost a little faith at the mo as i almost crashed my plane 3times yesterday i hope it is just a volt problem.
thanks J
thanks J
ON, CANADA
Fraid the wouldn't work. As you see it's made for the carpet cars. But I might suggest the new Castle Creations UBEC. It will supply the voltage to the the rcvr. and servos without dropping voltage, at least little voltage drop. Not to expensive either. Check it out on their website. I'm in the middle of hooking one up right now. I use other UBECs on my bigger electrics but they are about twice the size and twice the cost. Havn't had a lockout yet.
The ones (BEC)by Dimension Eng are also very good and a variety is available
I have been using these plus the ALIGN ESC in my 400-700 watt setups
sofa sogood
sofa sogood
Thanks so much guys, all my faith is back in my DX7. i am flying with 100% confidence again.
Many thanks
Many thanks
ON, CANADA
I imagine in the next few yrs. they will all be switching BECs in the ESCs. Something that should have been done some time ago. Could have saved a lot of planes and choppers.
