do hitec servo arms fit futaba servos?
Old 10-30-2007, 12:22 AM
ryans1000
Default do hitec servo arms fit futaba servos?
do hitec servo arms fit futaba servos? this is on middle sized futaba servo.
thanks,
ryan
Old 10-30-2007, 01:04 AM
4*60
My Feedback: (41)
Default RE: do hitec servo arms fit futaba servos?
No they don't. They may appear to but don't mix them. They ar not the same.
Old 10-30-2007, 05:21 AM
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
NO!!
A.T.
ORIGINAL: ryans1000 do hitec servo arms fit futaba servos? this is on middle sized futaba servo. thanks, ryan
Not one Futaba horn (25 spline) will safely fit any Hitec Servo output shaft.
Futaba horns may appear to fit but will slip under mild loads, as Hitec horns are as follows:
Feather HS35, 45, HS-50 & HS-55 = 16 Spline Servo Horn.
Micro - HS-56HB only = 23 Spline
Micro Horn & Hardware Set for HS60, HS81 & HS85 = 24 spline
Micro - HS-65HB & HS-65MG = 25 spline
[Futaba 25 spline shafts (& horns) have a larger diameter]
Standard Hitec Servo = 24 spline
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Old 10-30-2007, 05:56 AM
Dr1Driver
A.T. tells you right. They may fit, but even if the splines are the same, the diameters are different and they will slip under load.
Dr.1
Old 10-30-2007, 06:40 AM
Rodney
Hitec, Appolo and Hobbico standard servos can use the same arms.
Futaba, DAD, GWS, FMA are also interchangeable; but
you can NOT interchange either group.
JR and Airtronics arms are interchangeable.
Old 10-30-2007, 03:58 PM
ryans1000
thanks guys. hobby shop told me the hitec arm would fit on my futaba but now I have to return it. you'd think a shop would know that
Old 10-30-2007, 04:20 PM
A.T.
ORIGINAL: Rodney. Hitec, Appolo and Hobbico standard servos can use the same arms.
Futaba, DAD, GWS, FMA are also interchangeable; but you can NOT interchange either group.
Still some misinformation abounds about which servo horns are interchangeable and "rebadged" servos. Users must be carefull that the horn to be used, even if same brand as detailed Post #4, does actually fit securely onto the output shaft.
Hobbico/Tower servos are OEM by Hitec and Futaba. Accordingly, users must make sure they use the correct horns for each model of any servo. Likewise, Futaba, DAD, GWS, FMA are not always interchangeable, DAD & FMA are OEM. GWS make their own (and OEM servos) but have also produced differing "standard horns" for their own servos. FWIW, JR, Sanwa (aka Airtronics in USA), Acoms & KO Propo are all made by the same manufacturer. Further information under Servo Control horn compatability
Regards
Alan T.
