reversing a servo (HS-625MG)
im making the back wheels on my aftershock turn, and i need the servo to be reversed. reversing the polarity dosent work, i found out the hard way and lost my reciver... is there a device i can buy todo this or does anyone have a guide on how todo it properly?
RE: reversing a servo (HS-625MG)
You could use one of these http://www3.towerhobbies.com/cgi-bin...&I=LXAFN1&P=ML and just connect the reversing leg of the Y. A JR version is also available.
http://www3.towerhobbies.com/cgi-bin...&I=LXAFN2&P=ML
but Mr G is right about reversing at the TX if that will do the trick for you. What radio TX do you have?
im not sure what "Tx" stands for but im using the stock stuff
[link]http://jrradios.com/Products/Default.aspx?ProdID=JRPR125**[/link] and
[link]http://jrradios.com/Products/Default.aspx?ProdID=JRP234275[/link]
both servos go into same slot on the reciver, theres a Y connector.
ORIGINAL: SPAAARTA! im not sure what "Tx" stands for but im using the stock stuff
[link]http://jrradios.com/Products/Default.aspx?ProdID=JRPR125**[/link] and [link]http://jrradios.com/Products/Default.aspx?ProdID=JRP234275[/link] both servos go into same slot on the reciver, theres a Y connector.
Instructions for DIY servo reversal, for those who can not use a TX function, are under "Servo - alterations, calculators, databases, repairs, convert to an ESC or winch & FAQ" on my web page.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Since you are on a non reversing Y, it won't do any good to use the reversing switch on the transmitter as both servos will reverse. You have three choices, buy a different brand servo (yes, Hitec and Futaba rotate in the opposite directions with the same signal), buy a Y with a servo reverser on one branch or, modify the servo internally by reversing the motor leads and the two outer leads on the potentiometer (not an easy job on some servos).
OK, my mistake, I didn't see "both servos go into same slot on the reciver, theres a Y connector" is your earlier post. Get the reversing Y I recommended earlier. Safest bet/cheapest.
