Throttle servo
Old 03-02-2002, 03:45 AM
funfly2005
Default Throttle servo
In your opinion what is the best throttle servo for a 40 size plane.
Im going for lightness with a plane and want to know some peoples responses.
Jim
Old 03-02-2002, 01:10 PM
bob_nj
My Feedback: (62)
Default Futaba
I can give a Futaba response since that's what I have. I've always used S133's for throttle. They've given me good service. It's always a good idea to keep an eye on any servo. When they start to act up, use them for parts and just replace them.
Old 03-02-2002, 01:53 PM
Vince
The standard servos that came with your system will do just fine. The Futaba S148, and S3001 are excellent standard servos, and will give very good service.
Vince
Old 03-02-2002, 06:20 PM
funfly2005
Yes, I know that the standards will give me good service but i want to go light. I like those hitecs alot. I have some hitec stuff and it has never given me a problem. What is a good throttle servo made by hitec.
Thanks again,
Jim
Old 03-03-2002, 11:02 PM
Dansy
My Feedback: (53)
Dansy's Avatar
Hi,
I used a Hitec 101 micro servo on the throttle of my Hovering Cobra.
I should ad it right behind the engine, so I only have a small pushrod.
Daniel Dupont
Old 03-10-2002, 08:22 AM
funfly2005
What about those hs-81. Is that a good throttle servo for a 46.
Old 03-10-2002, 10:59 AM
Ed Smith
If, as you keep saying, you like the Hitecs a lot, then buy them. Dont listen to anybody else.
Ed S
Old 03-10-2002, 11:16 AM
Dansy
My Feedback: (53)
Dansy's Avatar
If you used a micro just installed it close to the engine.....because they are not powerfull servo for a normal size in the servo bay will work fine.
I used mini on my pattern plane but the digital type for reliable throttle position, but for the funfly/sport type plane throttle position is not that important.
Daniel Dupont
Old 03-10-2002, 06:46 PM
majortom-RCU
My Feedback: (40)
Default HS-81 throttle servo
At 32 oz.in. the HS-81 has plenty of torque to move your throttle, and saves a full ounce of weight vs. the standard servos. You could even go for the HS-60 Super Micro at 16 oz.in., but that would only save 0.16 oz of weight over the HS-81. You talked me into it, HS-81 will be my next throttle servo!
