Setup question for JR 9303 2.4 transmitter
NC
On a dual elevator setup with separate servos I can not get the flaps mixed with the elevator halves. When I throw the flap switch it lowers the flaps(ailerons in my case) and only one(right side) elevator. Seems that no matter what I try I can not get it to mix to both elevators at the same time.
I have the elevator mixed to Aux2 and they both will work like they should. Everthing works perfect until I throw the flap switch. Any ideas?
This really is not a major issue for me, I probably will never use it anyways. I was just curious if someone has done it or knows how to set it up?
My Feedback: (66)
RE: Setup question for JR 9303 2.4 transmitter
Dual Elevators
Plug one side of the elevator into the ELEV channel and the other side into the AUX. 3 channel. Go into the System menu and choose Wing TYPE. Jog over to the Mate line under ELEV and push the roller button. A box will appear with 4 choices: GEAR, AUX2, FLAP & AUX3, choose AUX3. You have just mated the AUX3 channel with the Elevator channel; the radio will now refer to these channels as REL (right elev.) and LEL
NC
Hey thanks for the help.
I thought that was the correct way to do it but since I had a mix setup to combine elevators it didnt work at first. I guess they were canceling each other out or something. After getting rid of the mix and doing it as you suggested It works perfect.
So many more features than the DX7. slightly similar but many different options to choose from.
Thanks again, much appreciated.
