There is a tracker ll
MD
Hi guys
I have just received the polks hobby tracker ll that has been on order for 7 months I have not had a chance to set it up as yet
but i will inform you of the progress
Hatman
Hatman
UT
Congratulations!!!
It looks like you're the first recipient of the Tracker II to post on RCU.
Any chance of pictures??? Mine's probably sitting at Canada customs right now...
MD
Sorry
I took it home to test it . It is a little wider then my jr trans . I hope the next design will allow a download feature
Hatman
Hatman
My Feedback: (7)
Just got mine Friday, seems like a great radio. a little big for my hands, but I fly with a tray so no problem. You guys with big hands would like the way it feels. Will provide updates as I become more famaliar with it. Still stuck in winter in Wisconsin so field tests may be a little while. Latter Craig
Does the Tracker II look like the picture on Polks website or has the case been updated? If it is the same you won't need to post a picture...
That is good to hear. Mayhaps Polk will update the site soon. They have many inovations in the Tracker II. The website on the other hand could use some attention.
IA,
I just received my Tracker II radio today!
I have only had a few minutes to look at it but, it looks just like the picture on the web site except, the battery meter says Polks Hobby and it doesn't have any volt markings, just a red line that changes to chrome.
There is a digital read-out of the voltage on the LCD.
I looks like this radio will be NO PROBLEM to program.
I had no trouble figuring out how to change the channel of the transmitter, and the Seeker reciever was very EZ to set up as well.
I hope to use the Tracker II this weekend.
merlm
merlm
UT
Aparrently there have been so many comments at the trade shows about it's looks that they're considering modernizing the case for the next revision. Mr. Polk had said it was very similar, but I didn't know how close.
As for programming ease, the manual makes it look easy - I can hardly wait till mine arrives to try it myself.
How's about when used with other brand receivers? Has anyone had a chance to try it yet? Rcdemon had mentioned in another thread that:
Has anyone had problems with this yet? Has anyone even tried it?
...the receivers will have to be tuned in pretty close to the Crystal for them to work with the radio.
My Feedback: (7)
I have tried using the radio with Hitec and Jr receivers. Some are glitchey and some don't work at all. I assume that this is because they are not in tune with the channel 12 crystal that I'm using. I'm on the fence as far as using the receivers and getting them tuned or just selling them and buying the Seeker receivers' from Polk. The Seeker receiver works great! Does anybody now where a person might send the receivers to have them tuned? More updates later when winter goes away. Craig
MD
I don't know if it will work with a dual conversion reciever I will not work with any pcm!!! I have tried it with my fm futaba OK
JR dual conversion is ok on the bench I will test it at the field
when the weather brakes
hatman
hatman
UT
Did you have flourescent lighting on anywhere in the house? My Hitec receiver goes nuts when some of my flourescent lights are on, but not with others.
Hatman - they never said it would work with PCM.
My Feedback: (7)
None taken. No I was not swapping cyrstal. Yes there was floresent lights. I'll try more test upstairs. My JR receivers are the single conversion ABC&W type. They are FM though, will they work. Maybe I should ask Polk about it.
MD
The scanner part of this radio is fantastic !!!! It goes crazy when
you have it on scan mode and another trans is on (beeps & Blinks the freq) They say it will do 3im interference This I cant check.
Hatman
Hatman
UT
Damn, I wish mine would hurry up and get here. The customs agents at the border are probably scratching their heads trying to figure it out before they allow it to enter Canada.
It's frustrating to have waited since September for this, and have to settle for reading everyone elses experiences rather than playing with it. It was shipped via USPS with no tracking number, so I can't even check where it is. :disappoin
MD
strato 911
Everything good comes to those who wait I'm sure it will be there
before long I got one and cant get to use it because of work.
Oh well
Hatman
Oh well
Hatman
rcdemon
I remeber reading somewhere that JR radios used a positive (+) freq. shift and Futaba uses a negative (-) freq. shift. (or maybe it's the other way around?)
I think that there is a screen that shows "PPM (-)", you may need to change the - to a + depending on the brand of receiver you are trying to use.
Just a thought.
wrecker5 (at work)
merlm (at home)
Just a thought.
wrecker5 (at work)
merlm (at home)
UT
I don't need the manual to answer that one - The Tracker II has no trainer port. There has been enough interest though that they are considering putting one in the next revision.
If you would like a copy of the manual, send me an email or private message with your email address.
Hello
Just received my Tracker II, I'm having a problem with setting up two servos in the wing for the ailerons. I know the Ch 1 and slave Ch 6 can anyone help me though this set up. Thanks dave
