2 battery power setup
After reading a lot of stuff about Voltage drop lockout on Spectrum, I've decided to go with a smaller 6V powering the Rx only & having A123 power the servos.
I need a diagram how to hook it up.
Thanx,V.
Thanx,V.
RE: 2 battery power setup
ORIGINAL: Josey Wales
Why not just use a single 2s A123 pack ?
Exactly, I could not agree more, it's battery capacity that you really need, & the ability of your batteries to supply enough current when required, A123's are perfect for that.
Thanks for the info guys, i might go that route.
But i would still like to have a diagram on how to hook up a separate battery for the Rx only. Anyone?
My Feedback: (44)
IMO that setup does nothing to improve your chances of getting a airplane safely on the ground because of component failure. As a matter of fact it decreases your chance. You are adding more components and not getting any redundancy.
I for one would be interested in what model airplane and setup you are thinking about.
My Feedback: (61)
NJ
ORIGINAL: rcairflr
My Feedback: (13)
MN
I have used that set-up for mechanical retracts.
It does serve a purpose, but just for mechanical retracts. The idea is that if your retracts don't go up completely, and the servo stalls out, it won't drain your main battery pack.
Greg
Greg
You're right Greg, it is simple(r) for just one servo. I'm trying to figure out how to "safe-proof" an sudden battery drop to the Rx
I will be setting up Spectrum 2.4 for the first time & trying to figure a way to insulate the Rx from a high current draw of digital servos.
Maybe this is not the right path.
My Feedback: (44)
You still did not tell us what airplane you are putting this in so we have an idea of your current draw. Just because you are using digital servos does not mean you are going to have a lot of current draw. The bigger the airplane the higher the current draw because of more load on the servo.
Depending on the size of your airplane, why not just use a singe 2S A123 battery as listed above or go with a dual battery setup into your receiver. On my 35% Extra 260 with 1 JR8711, 6 HS-5955's and 1 HS-5945 I use (2) low impedance 2000mA NiMh batteries each with it's own switch into the receiver and easily get 6-8 (10) minute flights as well as redundancy.
I think you are making too big of a deal that you are using Spectrum. With good quality low impedance 6V NiMh or A123 you would be just fine.\
The only other thing I would do if using only one battery would be to still run it thru two switches. Once again, this is for redundancy, a switch is more apt to fail than a battery.
ORIGINAL: exeter_acres
yes, which plane is it for?
CMPro Sukhoi
ST 2300 (glow driver) separate power pack
Graupner/JR DS8077 (2x) ailerons
Graupner/JR DS8077 (2x) split elev
Graupner/JR DS5491 (1x) rud
Graupner/JR (1x) STD thr
I am probably over cautious now but I lost a plane due to interference lately, thus the switch to 2.4
I have the "old" Spekrtum Rx which reboots lenthly at 3.8V (or 4.2V?)
Most of my planes now have Nicad setup, one has Nihms BUT i feel safer using Nicads
Charger> Triton I
I've read A123 are easier to maintain than lipos (no balancer needed) but maybe i should stay with 2 large Nicads in parallel (2 switches)
Thanx for helping,
V.
