Servo lead chafing
Servo lead chafing
Are the long servo leads now in use on large aircraft causing any problems with wire chafing? I was amazed recently by how quickly the exposed edge of a 1/16 inch thick plywood former will saw through the pvc insulation around a servo lead. This could potentially lead to a disaster if two adjacent wires are abraded to the point that a short circuit occurs. Some servo leads are buried in the fuselage or wing and canot be easily inspected. I am curious if anyone else has experienced problems with this, I will certainly pay more attention to wire routing and securing in the future.
RE: Servo lead chafing
Hey guys,
This is an old post, I know, but it is the only thing I can find on the subject and it looks like it never went too far....I didn't want to start a new thread.
Anyway, has there been any discussion on this elsewhere that I can refer to? I'm just about done with my Aeroworks 260 (50cc) and am a little concerned about the servo wires and extensions being routed through the holes in the plywood bulkheads. I guess it is mostly in the dual elevator servos but it applies in other spots as well.
Is servo wire chaffing a real problem or am I worrying about a non-issue?
Tom
Tom
