HiTec rcvr compatability
MN,
Sorry if this has been covered before, but I couldn't find same from searches:
I have a HiTec radio, the flash 5x, and a hitec receiver.
The servos I really really want to purchase only have Futaba or JR plugs on the wires.
Will either of these work with my reciver?
Time to get out the soldering iron?
UT
Here's a zip file images of the different connectors.
Hitec and JR are identical, and will also fit in Futaba, and the new Airtronics Z-connector (not shown in my zip file).
MN,
Thanks so much!
Let me show you what I ordered:
http://www.aeromicro.com/Catalog/gws...r__1489269.htm
1/4 scale torque in a micro servo, with dual ball bearings _and_ metal gears.
UT
Your link didn't work, but I assume you meant these GWS Micro Dual Ball Bearings Metal Gears Servos (JR).
UT
RCU is adding extra characters into the link for some reason. If I go to edit my link, it's still correct. I'll try to correct it somehow. If I can't, goto http://www.aeromicro.com/Catalog, and click on"Servos", then "GWS Micro Dual Ball Bearings Metal Gears Servo (JR)"
