FUTABA SkySport radio system - connect to PC
Hi everybody.
I just Buy a Futaba SkySport T4YF Radio System.
I'm wondering if it's possible to connect it to a PC, to a simulator???
Thanks...
This is the back side of my radio
Thanks...
RE: FUTABA SkySport radio system - connect to PC
You should be able to connect that transmitter to almost any simulator. The actual connector will vary based upon which simulator you use. Do you have a particular sim in mind? I use Realflight G3.5. This came with a connector cable that allows me to use my Futaba transmitters with Realflight.
So the simple answer is "yes you can". However you need to determine which sim you want to use. There are several commercial and a couple of shareware / freeware sims available. RealFlight, FSOne, FMS and others.
I use AeroFly Pro Simulator
I don't have a connecting cable, this is what I'm looking for.
Can You know some link where I can buy somer cable that can connect my radio to PC...
If you have no cable or controller with the copy of AFPD you have, then you don't actually have AFPD[&o]
Good luck,
Pete
Good luck,
Pete
Hi,
With this USB-interface is added a conversion cable square to jack female mon :
http://cgi.ebay.co.uk/Usb-Flight-sim...QQcmdZViewItem
http://cgi.ebay.co.uk/FMS-Simulator-...QQcmdZViewItem
http://cgi.ebay.com/FMS-Simulator-US...mZ360012250775
http://cgi.ebay.com.my/FMS-Simulator...QQcmdZViewItem
http://www.nextag.com/Futaba-Square-...43/prices-html
http://www.shopping.com/xPC-GWS-Futa...-Gws-GWFSM002C
or ... goooooooogle
Stop ou encore ???????
Of course, except for the freeware FMS, you will need for every commercial simulator the original dongle connected to your PC.
Olivier
or ... goooooooogle
Olivier
Nah, the normal reason given is "The dog ate it" At least that's the excuse I usually gave the teacher when I forgot to do my homework.
Cheers,
Pete
Cheers,
Pete
