Does Hitec Eclipse work with Futaba 2,4 Module?
Hi, today a guy in my field, has just mount a Futaba Fasst module into his 35 MHz. HiTec Eclipse Tx. and succeed a perfect range check then many successful flights.Is it common there too such a conversion?
RE: Does Hitec Eclipse work with Futaba 2,4 Module?
I've used the Hitec 72 mhxmodule in my 9Cap 72 mhz many times with no problems. Many of the Hitec / Futaba parts are interchangable.
Hi Deadeye,I was mentioning a 2,4 GHz Futaba Fasst module into a HiTec Tx.If its so common and available,why complaints still there on lack of HiTec 2,4 GHz gear?
Because they are different manufacturers. And there are some that think mixing and matching brands is a sure fire way to crash. I've been doing it ever since I started in the hobby, and have never had a problem mixing hitec and futaba servos, crystals, modules, switches, RXs, TXs, and everything in between. The Hitec and Futaba modules share the same wiring, so it only makes sense that it would work. Good luck!
