Who prefers heli transmitters to fly airplanes and why.
I’m new to the hobby and have noticed various comments regarding some folks preferring heli transmitters to fly their airplanes and since I’m in the market to purchase a radio system (Looking at the JR 9303) I thought I’d try to find out why.
OR
RE: Who prefers heli transmitters to fly airplanes and why.
I'm using a JR 9303 heli version to fly airplanes. Why? Because I had one that I bought a couple of years ago along with a new heli kit. Never did get the heli finished, but decided to use the radio for some new airplanes. I wasn't sure I liked not having a throttle rachet , so I ordered the rachet spring (like the airplane version uses) and installed it. The only thing I can point to about the heli version I like is the triple position switch on the left side that will be great to use for setting up triple rates. It's the switch that's normally used for "Idle Up" for helis. Would I buy a heli radio if I just wanted to fly airplanes, probably not.
As far as the 9303 goes I love it (either version). The only real down side for me is the fact that the timer can't be set up so it starts when the throttle is advanced. This can be done with Futaba radios and is a great convenience.
Hope this helps.
Jim
Hope this helps.
Jim
My Feedback: (41)
The programming in both style tx's is the same.
The differences are a couple of tranpositioned switches which I prefer, smooth throttle and the trainer button on the air version is replaced by a spring loaded toggle switch on the heli version. The heli version also defaults to a heli when setting up a new model.
I'd flown Futaba air versions every since I started but when I decided to go with the Spektrum version of the 2.4GHz implementation rather than Futaba's, I got a DX-7 to play with and got the heli version based on the advice of the LHS owner who uses them on his GS stuff. I'd also read other folks saying they liked the heli version mostly for the smooth throttle as it's an issue especially with some of the 3D maneuvers.
I flew the DX-7 on my glow models until my X9303 got here and then used it on my gassers. The X9303 is a heli version too and I really like the differences. As mentioned, if you decide you don't like the smooth throttle you can install the ratchet device on the X9303. The DX-7 comes with that device, but if you decide you want it for the X9303 you'll have to buy it extra from HH or an LHS.
In order to get the smooth throttle on the airplane versions, can't you remove the ratchet mechanism?
OR
ORIGINAL: P-51B
Jim
VA
If you take the back cover off and remove the screw that operates the rachet function then just flip that piece over and reinstall the screw you get some tension on the throttle stick but it is smooth with out bumps.
OR
ORIGINAL: badazzbusa
Jim
Most every plank pilot (sorry, airplane pilot) that has flown my Funtana or Yak on my heli radio has asked me how to convert thier throttle ratchet to heli style, a few of the 3d guys had me to it right then and there at the field.
And on the 9303 I really like the spring loaded switch over that push button any day.
Simply the "Mode" discussion with a different twist.
Whatever you like---- different strokes for different folks.
Thanks everyone for your opinions, advice and comments on this subject. I think I’ll end up going with the heli configuration, as from what I gather the placement and kind of switches can cross over from heli to airplane use easier than using the airplane version for controling a heli. Is this the general concences? I don’t know if I’ll ever try helis, but if I do, at least I’ll be prepared. Oh, by the way, does the JR9303 remember the last model that was flown after it is turned off? I’d hate to have to get out of the heli mode every time I turned the transmitter on to fly my airplanes.
My Feedback: (41)
ORIGINAL: sos95714
The only time you'll see a heli pop up is when you go to program a new model (or you've been flying a heli...)
it'll default to a heli and you just select either an airplane or sailplane from that screen.
