HS77BB servo for retracts
FL
I am using the HiTec HS77BB proportional servo along with a servo rate reducing unit for the retracts. The servo end points are adjusted via the DX7 travel adjusment. I am getting a continuous hum both when the gear is fully extended and retracted. I can cancel the hum by reducing the travel but eventually after recycling the gear several times the travel is reduced and the gear hangs. Has anyone had a similar experience with this servo?
RE: HS77BB servo for retracts
ORIGINAL: Rafael E I am using the HiTec HS77BB proportional servo along with a servo rate reducing unit for the retracts. The servo end points are adjusted via the DX7 travel adjusment. I am getting a continuous hum both when the gear is fully extended and retracted. I can cancel the hum by reducing the travel but eventually after recycling the gear several times the travel is reduced and the gear hangs. Has anyone had a similar experience with this servo?
Hitec HS-77BB Low Profile Servo - ailerons specifications
4.4kg.cm(61.1oz.in) at 4.8v - 5.5kg.cm(76.3oz.in)
HS-75BB Retract Servo specifications
6.6kg.cm(91.65oz.in) at 4.8v - 8.2kg.cm(113.87oz.in) at 6.0v
perhaps E.P.A - A.T.V - Dual Rates differences will also assist.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
