14MZ tech questions
14MZ tech questions
I have just started programming my 14MZ with my old jets ( kangaroo ), but can up with a little programming problem. I have two rubbers one in channel 4 and the other in 5 channel. I have channel 4, that is slower and has less travel the channel 5, they are exactly the same servo. And have the same ATV, with out any D/R or P. mix and both have the same trim. The only difference is in the sub-trim menu, channel 4 has +41 and channel 5 has -52, to set them up straight. Is there anything in the back round programming that I'm missing or what happening?
RE: 14MZ tech questions
I have not tried switching servo, but this servo work perfectly with my 9Z, and yes I'm using the recommend channel use. I have to change all the position on the receiver.
QC, CANADA
I have the same problem unfortunately also without answer....
I also just got my 14 MZ and activated the ailevator function (chan 1-2). One of the elevators reach 135% while the other is only at 65% or so and 65% stick travel. If I go all the way on the stick, the first servo stays at 135% while the other one reaches 100% when the stick reaches 100%.
I'm in the process of registering to Futaba and accessing the 14MZ.com forun seems to be the best solution IMO.
ORIGINAL: kelly vallee
Later;
D.W.
