Discussion - Futaba 8UHFS channel swapping
Reply
Old 01-27-2008, 10:47 AM
petn7
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Discussion - Futaba 8UHFS channel swapping
Is it possible to to use the Channel 7 switch on the transmitter to control a servo plugged into the channel 5 or channel 6 slot in receiver?
I looked in the manual and found nothing that talked about this issue.
P.S. I'm brainstorming a model submarine design and I want to control the bow planes with channel 5 or 6 (channels 1-4 will control throttle, stern planes, rudder, and ballast).
I need a switch/servo that has 3 positions: dive, neutral, and rise. The switch for channel 7 on the 8UHFS seems to be a perfect fit for this.
If channel swapping is not possible, does anyone know of any micro receivers that are on surface frequencies and have 7 or more channels? For example, there's a Berg receiver that's small enough for my application (and has 7 channels), but it's on an aircraft frequency.
petn7 is offline
Old 01-27-2008, 05:37 PM
wonderboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Discussion - Futaba 8UHFS channel swapping
Yes.
Step 1: Pick which channel you want to use. Lets say Channel 5.
Step 2: Turn off the normal Channel 5 function by using PMIX-1.
- Go to the advanced menu
- Select PMIX-1
- Hit the "+" button while "INH" is blinking to enable (don't worry if it says "ON" or "OFF" at this point.
- Select "GYR" as the master and slave channel (this is the label for Channel 5 on heli modes)
- Set the Percentages to -100% (you'll have to toggle the switch for Channel 5 to get to both)
- Set the Switch direction to "Null" (doesn't matter which switch is selected)
Step 3: Mix Channel 7 into Channel 5 using PMIX 2
- Select PMIX-2
- Select "CH7" as the master and "GYR" as the slave channel
- Set the Percentages to +100% (you'll have to toggle the switch for Channel 7 to get to both)
That should do it. There may be other ways too, using offsets or something, but to me this seems the most straightforward.
wonderboy is offline
Old 01-27-2008, 05:54 PM
petn7
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow, thanks for the reply.
petn7 is offline
