Driving three or four channels of motors
Reply
Old 02-02-2008, 03:11 PM
CrunchyFrog
CrunchyFrog's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Driving three or four channels of motors
Dirt cheap is the only way I can engage in any hobby at all for now.
Can the radio sets I see in a hobby store drive the fifty-cent generic motors I've pulled from r/c cars ? I might actually buy a hobby-grade tx-rc setup--if it could do that. Do the channels tend to be specific as to whether they drive a servo or a motor? Is there a brand name that makes what I'm looking for ?
It's for my sub, whose "servos" (reappropriated motors) are out in the wet areas. When it comes to using a $12 servo or using a "free" motor I've got lying around, I'll always risk a motor instead.
CrunchyFrog is offline
Old 02-02-2008, 03:51 PM
Cambo
Cambo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Driving three or four channels of motors
You can't use a reciever as a ESC to control the motors RPM. You can however hook up as many ESC's you want to each channel. What are you trying to do?
Cambo is offline
Old 02-02-2008, 11:12 PM
CrunchyFrog
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm trying to run three channels:
1. Forward/stop/reverse drive motor (toy r/c car motor)
2. Rudder fins left / stop / right (using toy r/c car motor)
3. Diving fins up / stop / down (using toy r/c car motor)
I've been running with toy r/c car boards, and the ability to vary the speed isn't important--not even on the forward drive. I'm just wondering if I can upgrade to a hobby-grade tx-rx rig--and have each channel control one of my essentially free, scavenged motors, rather than a servo. Aren't servos about $10 - $20 apiece?
Old 02-02-2008, 11:43 PM
Cambo
Cambo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So you are trying to drive a control surface using a electric motor. No it would not work. Servos use a small chip that tells the motor to stop at a certian spot so when you move your stick 75% up, the servo moves 75% of its travel. Your reciever/transmitter does't have this knowledge. Just buy a couple servos. A couple non ball bearing standered servos can be had for 14 bucks.
Cambo is offline
Old 02-03-2008, 12:28 AM
CrunchyFrog
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks very much!
I have to differ, though--I actually ran my sub satisfactorily last year with motors on the control surfaces. I configure stops at the ends of their travel.
I run the control-surface motors in the sub's "wet" area. Can't risk $28 worth of servos--that would shut me down the first time my servo sealant leaked. Even $10 apiece servos would be hard to do. But I've been doing it with a dollar's worth of wet motors each run.
I take it I wouldn't find a radio rx that would run three motors. That's what I'd buy at this point, if I could find somebody who makes it.
Thanks again !
Old 02-03-2008, 09:25 AM
Cambo
Cambo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Interesting, than maybe it is possible. Did you have the thing set basically just setup for centered=motor off, left=motor on, and right=motor reversed?
Edit: Oh, BTW, servos aren't shot the second it leeks. All you have to do is dive and get the sub, take them out, and let them dry for a day or so. They should be good as new. I here of people recovering recievers, servos, and gyros from aircraft that crashed into water. You can also water seel them wich can be done using many different techniques
Cambo is offline
Old 02-03-2008, 10:46 PM
CrunchyFrog
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I haven't gotten it sophisticated enough for a spring-loaded center position--for now it just has left and right. I should probably add the electronics were from toy Wal-Mart r/c cars.
Thanks for the tip about servos on sunken airplanes.
