Hitec 5245
Reply
Old 02-15-2008, 09:24 PM
3DAP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hitec 5245
Is anyone having any problem's that you would advise against using the 5245 as a throttle servo in a 29%???
3DAP is offline
Old 02-16-2008, 03:15 AM
masonman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hitec 5245
If your a Hi tec guy why not a hs-425 or hs-475.Under 20 bucks.
masonman is offline
Old 02-16-2008, 12:12 PM
P-40 DRIVER
P-40 DRIVER's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Hitec 5245 coupled with a 4-40 Carbon nyrod and ball links would work extremely well for your application. The Karbonite gears used in the 475 are not recommended in gas applications due to vibration issues. A good quality servo and linkage are recommended for 3D due to needing very precise throttle control.
P-40 DRIVER is offline
Old 02-16-2008, 03:46 PM
airbusdrvr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: P-40 DRIVER
What is the source of the advisory and what is the issue?
airbusdrvr is offline
Old 02-17-2008, 02:18 PM
P-40 DRIVER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hitec used to post this info on their support page, but I don't see it now. They had some issues with Karbonite gears failing due to heavy vibration in giant scale as well people using locktite. Their advise was to use only metal geared servos in giant scale. This is also the advise given by Troy Built Models website. I would probably go the 425 route over the 475 route for that reason. The 5245 is a much better servo the either of them for the application in question.
Old 02-18-2008, 01:45 AM
3DAP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thankx for input,
I was told that the 5245 would be a good set up for throttle due to its metal gear and fast transit time. I was going to put a 5625 in like in my 27%, bipe but transit time is slower. I just wanted to see if any one had problem's with them. Now after some research I am finding out that they are pretty good! There is a lot of people on rc group's running them in electric's as elevator servo's. Thankx again
3DAP
3DAP is offline
