On Is Off And Off Is On ?
Reply
Old 02-16-2008, 02:30 PM
CrunchyFrog
CrunchyFrog's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default On Is Off And Off Is On ?
I just extricated a toy 3-channel r/c system from a fireboat to put it in another hull.
Running great...the water-cannon channel's confused though!
It's supposed to be
Click ON button: water cannon comes on and stays on.
Click OFF button: water cannon quits and stays stopped.
I tested each stick and button before disassembling the donor boat.
I still have this functionality in the recipient--except now the OFF button starts that third channel and ON stops it. With a meter, I see the output ramp smoothly up to 8 - 9 volts each time I press OFF, then back to 0 when I've pressed ON. Amps output (10A and 200mA ranges)--0 Amps. Battery charge is fresh.
Reversed leads wouldn't really explain this turnabout.
I didn't modify the board itself, although it's hooked up to a different set of motors, and instead of its 9.6 v battery pack it's running on 8 AA cells.
Anybody seen this before ?
CrunchyFrog is offline
Old 02-20-2008, 03:14 AM
redfox435cat
redfox435cat's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: On Is Off And Off Is On ?
the channel is obviously reversed. In programmable radios this is simply a matter changing a setting. Don't simply reverse the leads. that will burn it up. The control function is not a matter of changing voltage. Though I'm not familiar with your exact radio I'm assuming it had 3 leads. plus, minus and a control lead. if it does then you can get one of these
[link=http://www.aeromicro.com/Catalog/dionysus_design_servo_reverser_3975198.htm]servo reverser[/link]
if not then their using some weird control scheem.
redfox435cat is offline
