Servo Eyelets
Servo Eyelets
Hi all, Installed some servos today, and a bit curious about the eyelets that came with my JR 537's. I read in my plane's manual that I shouldn't compress the rubber grommets too much by excessively tightening the screws, but it seems that these eyelets compress the grommets a bit....I guess this happens to everyone? Maybe it just makes the screw hole area stiff?
servo eyelets
some people install the eyelets upside down. This does allow you to compress the groumet too much. Make sure the eyelets are installed from the bottom of the servo and You will not be able to over compress the eyelets.
Good Luck
Lee
Good Luck
Lee
