hitec jumper wire
Reply
Old 02-27-2008, 07:18 PM
pault
My Feedback: (34)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default hitec jumper wire
a friend told me that the jumper wire is not needed on the rcd 3800 reciver if you are using jr transmitters...it will work even if the jumper wire is completely removed........the jumper is only needed if you use futaba....any truth to that statement........thanks....pault
pault is offline
Old 02-27-2008, 07:45 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: hitec jumper wire
Yes there is some truth to that statement although I can,t attest to which it is, jumper inserted for positive shift and the jumper removed for negative shift or the the other way around. Either way just try it and if it does not function just try it the other way.
This only applied to the shift selectable version of the supreme. Most Hitec rx's are either/or but not selectable.
John
JohnBuckner is offline
