reciever antenna lenght?
My Feedback: (34)
i am replacing the antenna wire on several hitec and jr recievers i bought off a friend that has gone 2.4........the wires have solder joints ,so im not sure if the lenght is accurate....are all 72 mghz antennas the same lenght regardless of the brand?...they are a 600 jr, a 700jr, a 3600 hitec, and a 3800 hitec.....i have measured all of them and the antenna lenght ranges from 37 inches to 41 inches.....any feedback?.........thanks...................pault
RE: reciever antenna lenght?
The industry has pretty much standardized on a 1 meter long antenna. Anything from 37 to 41 inches should work well. All these receivers are base loaded to give optimum performance with that antenna length regardless of the frequency you are operating on.
After you install them and route the antenna around the other stuff, they are completely out of tune anyway. 40 inches will work fine. Tower sells antenna wire for Futaba's. Any 19 strand wire 24 to 26 gauge is OK.
