Got my Airtronics RDS8000 2.4 Gig Radio!
TX
RE: Got my Airtronics RDS8000 2.4 Gig Radio!
ORIGINAL: flyinbr
Not yet waiting for the weather to get better up here.
How do you like the programming menus?
CR
NY
sat down last night and programmed the first plane in the radio. At first I had a little trouble finding things but with a little reading I started to figure it out and the more I worked with it the easier it got. So far I like the radio just got to get familiar with it.
TX
ORIGINAL: flyinbr
CR
GA
I got mine too, with 2 rx deal from tower for $214 shipped .
I have one ULTRASTICK60 and the other one is giles 202, I bind both receivers under respective models, Now here is my problem, If I turn my TX ON lets say for giles 202, and both models sitting side by side in ON position, both airplanes do the same movements( like if I move throttle up, throttle on both airplanes do the same at the same time.)
like one tx is controlling both rx on the same frequency.
On my SPEKTRUM DX 7 it has model match, the other plane won't do anything until I change the model name.
Am I doing something wrong or they do not have seperate programming like DX7.
Kindly help.
Kindly help.
MN
You're not doing anything wrong. The same thing would happen with a 72mhz radio. Model Match is a proprietary Spektrum/JR feature, so you won't find it on other systems.
TX
ORIGINAL: SANDSTORM
Kindly help.
Kindly help.
CR
