Super secret club info needed
CA
I'm trying to set up a 14ch Fasst reciever. Only problem is my instructions tell me I have to get access to the super secret flyers club to find out what the channel groupings are for 14 and 7 ch recievers. Yes I'll send my letter in requesting admission to the club but in the mean time can I beg pretty please and learn how to connect my dang servos?
I just recieved the radio yesterday 12z FASST and I'd like to fly tomorrow. Don't really want to unbox the 7c thats ready to be sent back for a zguid fix.
This is a fine catch 22 if I ever saw one. Sheesh!
RE: Super secret club info needed
ORIGINAL: altavillan
CA
It's the new 2.4 Fasst. There's a 1 page addendum that tells you to go to the Futaba flyers club website to get channel assignments for the 2.4 recievers because they are different than for the 72 mhz grouping.
This is the only info with channel assignments that I can see. Here is a link to the one on the open page.
http://www.14mz.com/downloads/T12Z_update_V1.doc
CA
Problem found Evan though the model set up says it's on the right reciever the channel control doesn't shift when selecting a different plane.
CA
correct. What caused the confusion was hooking up the rudder servo to ch3 as per function. It sat there doing nothing till I touched it and then it went nuts. One time I cycled the tx through 7ch /14ch reciever set up and it worked normal. Unfortunatly I can't duplicate it and it's back to going nuts when I touch it but will not respond to stick movment. Aileron,ch4 is the same thing. Whats odd is I installed a 7ch reciever and everything works as it's suposed to.
Think I need some warranty work.
