6V battery problem
BC, CANADA
6V battery problem
hi
I recently soldered up a 5 2/3A cell pack as an rx pack for my plane. When I hooked it up my servos went nuts, vibrating back and forth. I have a JR R600, and JR 517 servos, that otherwise work fine... whats going on? it just occured to me, although very unlikely, I may have had the polarity wrong. could that have caused that problem?
UT
6V battery problem
When 5 cell packs are freshly charged, they typically exceed 7 volts. Some receivers can't handle the extra voltage. Either use a 6V regulator, or wait a few minutes and see if the voltage drops down enough to get rid of "the shakes".
BC, CANADA
6V battery problem
ok, i admit i overcharged the battery a bit at first, so it may have been over 7v. what is a regulator/where can i get it?
UT
6V battery problem
Since I only use 4 cell packs (so far), I don't know where you can get them other than the local electronics store. Perform a search in this forum for "regulator" - it should give you tons of threads. This has been discussed frequently.
