Bad Servo
Reply
Old 03-12-2008, 07:28 PM
Cambo
Cambo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bad Servo
Because i don't want to wait for my extra ar7000 to come for my cap 27% i pulled the ar7000 i have in my heli (wich is waiting for a battery) and hooked it into my cap. I recently sold the matchboxes in hopes that i could simplify my system and just use the DX-7 with its programing features to setup dual elevator and rudder servos. So after alot of fittling with the programmable mixes i finally figured out how to get the two elevator servos to move in unison. However, the left one is really starting to act weird. Much weirder than it did when i was using mathboxes. The left elevator servo was moving much slower than the right one. I at first thaught it was the radio and almost had a panick attack since i had just sold the two matchboxes, however, i decided to try and set the daul rudders up and to my surpruse there was not a problem at all. No binding once the subtrims and epa's were figured out. I became suspicious of the elevator servo. So i took the left lead and plugged it into another channel. It acted VERY slow. I plugged the right servo into were the left one once was and it acted normal. The left servo is also making this noise as if it was binding. Do you guys think the servo is bad. I am wondering if this servo was somehow causing problems with my batteries before wich might be why i had a momintary lockout before i switched to the new firmware.
My setup
27% cap232
Dl 50cc
2 2/3A 6v 1400mah hyrimax batteries
6 s3305's from futaba
ar 7000
1 hobbico standered for the throttle
1500mah on the igniton
Cambo is offline
Old 03-12-2008, 07:56 PM
Ken6PPC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Bad Servo
If it walks like a duck, and quacks like a duck........
Ken6PPC is offline
Old 03-12-2008, 08:13 PM
Cambo
Cambo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
then it is not a duck . LOL, just kidding
I solved the problem. I tried a new battery and it worked like a charm. All four servos are right on. I also noticed a slight binding of linkage on that servo wich was causing the buzzing noise at idle.
Anyway, problem solved.
Cambo is offline
Old 03-12-2008, 08:34 PM
Ken6PPC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You said you were using TWO 6V 1400 MHz batteries. Are you now saying that both of those 6V batteries were so dead that they didn't have enough power to supply that servo? That sounds pretty strange....
The binding would make sense to slow the one servo down.
Ken6PPC is offline
Old 03-12-2008, 09:23 PM
Cambo
Cambo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I forgot to mention. I was using a spare 4.8v 600mah reciever battery that was sitting on the bench for the programming. The 2 6v batteries were not hooked up.
Cambo is offline
Old 03-12-2008, 09:47 PM
Ken6PPC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ah HA!
Ken6PPC is offline
