Dual Battery Setup
Reply
Old 03-13-2008, 01:29 PM
Piddler
Piddler's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Dual Battery Setup
I'm currently putting together the most expensive plane the I have ever built. I'm thinking about using a dual battery setup. I want to make sure that I understand how to do this. I currently have the single battery setup installed. I have one channel open on my receiver. From what I have read, I can hook another switch and battery up using the open channel. Will this provide an alternate power source if one battery goes bad? I plan on using 2 6v 1100 mAh batteries. Will both batteries decrease voltage at the same rate, but just slower than the single set up?
Thanks in advance,
Brad
Piddler is offline
Old 03-13-2008, 02:20 PM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Dual Battery Setup
ORIGINAL: Piddler I'm currently putting together the most expensive plane the I have ever built. I'm thinking about using a dual battery setup. I want to make sure that I understand how to do this. I currently have the single battery setup installed. I have one channel open on my receiver. From what I have read, I can hook another switch and battery up using the open channel. Will this provide an alternate power source if one battery goes bad? I plan on using 2 6v 1100 mAh batteries. Will both batteries decrease voltage at the same rate, but just slower than the single set up? Thanks in advance, Brad
Dual (Parallel) Battery Operation = Reliability & More Flight Time
Dual Batteries, isolators, 6v, voltage depression, redundancy, etc
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline
Old 03-13-2008, 02:32 PM
DougV
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Piddler
Thanks in advance,
Brad
http://www.hangtimes.com/rcbattery_faq.html
Scroll down to "Parallel/Redundant Battery Packs"
Doug.
DougV is offline
Old 03-13-2008, 03:32 PM
rcairflr
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Piddler
Thanks in advance,
Brad
What you said is essentially correct. I use dual Nimh setup just like you described, and upon recharging they both draw almost the same amount of current while recharging. If one battery develops a short it may rapidly discharge the other battery, but if one battery opens the other is still operating at it's full potential.
Another method would be to go with a larger capacity battery with 2 leads and run the one battery thru 2 switches. IMO a switch is more likely to go bad than a battery.
Even though I use dual battery setup, I check my batteries under load prior to every flight.
rcairflr is offline
Old 03-13-2008, 06:46 PM
libor
libor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am using this [link=http://mgm-compro.com/index.php?tid=backup-battery-switches-accusw4&PHPSESSID=78ea523c2d4407b88c4ed8ad9388beec]switch[/link] in this bird
[link=http://www.kolmanl.info/index.php?show=rlunak_foto_2#rlunak_foto_2]Lunak[/link]
libor is offline
Old 03-14-2008, 06:40 AM
Piddler
Piddler's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the links! That explains everything I wanted to know.
Thanks again,
Brad
Piddler is offline
