Best place to buy Sanyo Nimh cells from?
Reply
Old 03-13-2008, 02:12 PM
sodbuster 1
sodbuster 1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Best place to buy Sanyo Nimh cells from?
where's the best place to get Sanyo AA Nimh's from? Need 2700's with tabs
thanks for the info
sodbuster 1 is offline
Old 03-13-2008, 02:54 PM
onewasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Best place to buy Sanyo Nimh cells from?
2700MAh in a AA can---------I don't think so.
onewasp is offline
Old 03-13-2008, 03:04 PM
sodbuster 1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
absolutely yes!
Old 03-13-2008, 03:06 PM
oldvet70
My Feedback: (10)
oldvet70's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Go here; http://www.batteriesamerica.com/newpage3.htm Third item down. AA 2700mah Nimh with or without tabs.
oldvet70 is offline
Old 03-13-2008, 04:08 PM
rlmcnii
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 2700 AAs are physically and electrically fragile. Use them with great care.
rlmcnii is offline
Old 03-13-2008, 04:44 PM
fizzwater2
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've heard that too - I think it was some battery supplier website that said they wouldn't warranty them because they can be fried by fast charging, they have to be slow charged.
fizzwater2 is offline
Old 03-14-2008, 10:12 AM
sodbuster 1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what about A cells?
are they a better choice?
Sanyo does show fast charging the 2700AA at 2700mah as a spec??
Old 03-14-2008, 11:23 AM
fizzwater2
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It probably depends on the end use of the cells. The 2700 AA's are higher internal resistance, not good for high discharge use. Not sure about the A's, you'd have to look.
For a transmitter, the 2700's are probably ok, as long as you don't try to fast charge them.
Old 03-14-2008, 03:06 PM
Ernie Misner
Ernie Misner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Get AA cells, lighter than A's, but go for a lower mah, say 2000 or so. Very robust, hold their charge better, etc., and still four times the capacity than we had a couple of years ago.
Ernie
Ernie Misner is offline
Old 03-15-2008, 10:48 PM
misasi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[link=http://thomasdistributing.com/sanyo-2700-aa-rechargeable-batteries.htm]Sanyo 2700mah[/link] I picked these up and i must say im very impressed. they kept my tx on for about 48Hrs on a single charge. They do take a while to charge. My peak charger charged them at .3A over night and it went great. No tabs tho
misasi is offline
Old 03-16-2008, 12:47 AM
summerwind
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if you want to find out about Nimh cells and what happens when the capacity becomes more than normal, go to this site
http://www.candlepowerforums.com/vb/index.php?
these guys are flashlight NUTZ, and have tested and exhausted everything inside and out when it comes to Nimh technology..................bottom line though is that 2700 has pushed the AA cells to far and even Sanyo chose to back down to 2000mah when they developed the "Eneloop" batteries which outshine in shelf life and overall discharge rate and are less fragile when charged improperly.
the last set of 2700mah AA's i bought didn't perform very well after 3 months use in my off camera flash units that i use for photography.
also with the use of Nimh for my camera equipment, i learned that Nimh batteries are great in the beginning, but a cell can go flat on you just about as quick as a NiCad, but also don't seem to last as long either.
summerwind is offline
Old 03-16-2008, 01:52 AM
3DAP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
See what HANGTIMES.COM has to offfer aka NO BULLSH$T batteries. They have a lot of Sanyo cells.
3DAP is offline
