DX7 - Dual Evelator - Help
My Feedback: (24)
Is the best way to set up a dual elevator setup on the DX7 via Program Mix 5 or 6 (these mixes have the integrated trim feature) ? I set it up on Mix 5, but I cannot disable the switch (SW) feature. Cycling through the SW options, there is not a NO or NULL option. I want this mix on all the time ... with no switches to turm it on/off. Thanks. Bob
RE: DX7 - Dual Evelator - Help
ORIGINAL: BalsaBob
it is easy to miss -
go back -swith tx of
do the button hold and power on to get this first screen ( model /name /wing type - and look carefully you will see what I mean
My Feedback: (22)
When setup like this, how is the travel and speed of both halves of the elevator, I have read and also noticed that on my 8103 that when elevator halves are mixed like this, there is a slight lag in travel and speed of the slave channel, is DX7 also like that, or it is better than the Jr8103? Does servo sync feature help with this?
Thanks in advance,
Maqsood
Thanks in advance,
Maqsood
ORIGINAL: 747-RCU
Thanks in advance,
Maqsood
Thanks in advance,
Maqsood
This is "servo sync"----and it does perform as advertised
