Futaba to Jr Connector
I have an XS3 I just bought. I wanted a fail safe so I picked up the futaba failsafe. Stupid of me i didnt think about the connectors fitting into each other. Can I buy a connector for this?
My Feedback: (13)
Use a sharp knife and trim the Futaba connector to look like a JR connector. Jr servos plug into Futaba receivers without modification. I don't have Futaba fail safe, but I suspect it is a device that goes between the RX and the throttle servo. So your JR throttle should plug right into the futaba, and the failsafe plug (after trimming) should plug righ into a JR receiver.
My Feedback: (13)
No. all servos use three wires. one is positive, one negative and one signal. the positive and negative are never on pins 1 and three. If they were, then there might be a problem if it gets reversed. But since negative is generally on pin 1 or 3, and positive is on pin 2, if you get them reversed, postive is still in the middle and negative and signal are reversed. nothing bad happens. look at the color of the wire on the other servos. generally the negative is black or brown on all brands.
CA
For more information about different brands of connectors (and pictures!), try this link:
http://www.fatlion.com/sailplanes/servos.html
