frequency interchanges - hi&lo
My Feedback: (16)
AR
I know what the people who sell rx's( recievers) say but what if put a # 32 crytal in a # 24 rx to fly a plane all else being by the numbers . i have ended up with 12 rx's . some are different #'s like #33 , it seems to work fine with a #32 crytal in it . my 3 radios tx'x are 32 - 24 & 46 also what if i use 41 rx and 46 tx in other word correct crytals in not exactly correct recievers what if the difference bands hi-lo comes into play like #24 rx used w/ #46 tx i'm kind a new at this but not that new over a year thanks ps . of course i'm using matching crytals just not exactly the matching rx's i don't fly around a lot of other planes
Just curious what you answer was. Unless you are using some older recievers I am not aware of, you just change the crystal, doesn't matter if you go from one end of the band to the other. If it passes a range check it's good to go.
